![]() | Home > Technical (L322) > More responsive gearbox?Real or imagination? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
IIRC it's the rear passenger (RHD) side ABS sensor that sends a speed signal to the engine/gearbox ECU, and a few other places I dare say...
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Cheers Pete, sounds like you are right about which sensor supplies the signal.
Enjoy it, it won't last long, something will break.... |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 110 ![]() ![]() ![]() |
I have limited experience of ABS - wouldn't a seized / non turning ABS ring give rise to a light / code? My logic is that the car would think that the wheel was skidding (maybe only when braking) and I'd expect the ABS might actually be called into service(!) or at least an error flagged up.
It could do but you have to remember what it says on the boot and bonnet.... "Range Rover" this roughly translates to "Anything can and probably will happen"
Prior to my fitting new parts, I did have a moment due to an idiot whereby I had to 'stomp big style' on the anchors. The ABS seemed to work fine, as to 'were all four corners doing the same?' I don't know. As I was trying to avoid an impact and the car stopped quickly I thought no more on the subject. One of those 'Change of underwear moments'
