![]() | Home > Technical (L322) > Bushings and Arms |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
I always worry about ebay suspension stuff unless it's a known make and/or supplier. If you can guarantee the quality off the "net" then fair enough.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Advanced Factors Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Depends how long you plan on keeping it....
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
With age etc if I was keeping it I would f#£k bushes off and change arms with new bushes, used Delphi in the past with good success. Lemforder also decent. I recently changed the upper and lower rear hub bushes using a dedicated bush removal kit.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
As said before, if your keeping it avoid unbrand stuff, these cars are brutal on bushes and will chew threw anything other than OEM apart from i guess polybush etc.. |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 41 ![]() ![]() ![]() |
I suppose that a special car deserves special care, this one is still special - Im not quite sure its reached a point in its life where i can afford to fit a part that will do the job for one trip once a year. This is a working car. So thank you for pointing it out along with other responders, and will have to pay special attention to ensure I source quality parts. 2011 Vogue SE 4.4 TDV8 |
