![]() | Home > Technical (L322) > Updating the version for the Gap 11D tool? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
delete the updater, clear any cache and re-load the updater. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Version 2765 is only available to people with Beta access , which Pat at Gap controls.
...or you could do what Mike says.... |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Thanks Stan and Mike for the messages. I will try deleting the updated approach initially as I suspect there are some updates prior to the beta one. Re the PDF Full issue I am note sure where the FFRR here is placed as my previous Independent garage fitted several new sensors over a two year period. I understand now that they have not been the only ones in this. Hopefully they fitted the later sensor in the correct place last time fixing the problem. As said forced short journeys in my case doesn’t help but the RR is great so so be it!
Well reloaded the updater tool and again found the message that the tool was update at V400.00 B2742. perhaps Pat will confirm that in a response to my query on the Gap site? I'll worry about a beta version should a "red warning" appear and I hope I have not tempted providence.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Just to clear up one point - you don’t need sports mode and high revs to force a regen. You need more than a quarter of a tank of fuel and travel at over 50mph for as long as it takes for the light to go out. If you drop below 50 the regen pauses so you don’t lose any reduction in soot levels earned up until that point. Bish.
Hi bisnbosh 10
