Home > Technical (L322) > Scrubbed rears….
Markwood71
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Scrubbed rears….
Been told this is not adjustable- and possibly a bent rear subframe .
Thoughts ???
 Welcome Rosie J - The Newer Kid on the Block
RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights)
Post #612270 11th Nov 2021 8:57am
Pawl
It is adjustable, so you need to find another garage - lol.
However, it's unlikely to be an adjustment issue unless you've just had the rear toe arms / bushes on the rear suspension replaced recently.
Most likely is the toe arm joints worn - but all it needs a good visual inspection using a pry bar to check for play - wheels off the car. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #612275 11th Nov 2021 9:40am
Markwood71
Hi Pawl,
had the rear lower arms replaced a few months ago. was sent for "tracking" and all ok- have scrubbed a set of new rear tyres in 3 months . shocks and bags are good. been in for new front brakes, and obviously new tyres. Asked the garage o get it 4 wheel tracked and they took it to the local Hunter garage. they said it was either the subframe bent or completely shot subframe bushes. we looked at bushes and they seem ok.
i just wondered how much adjustment you could get and if 11mm was too much to bring back.
Post #612278 11th Nov 2021 10:08am
Pawl
Was it scrubbing badly before you had the rear arms replaced ?
If no, the scrubbing is obviously related to poor installation of the arms / failure to re-install the cam washers in similar position to when removed.
A bent subframe is obviously possible, but unlikely unless you remember a big impact & have had to replace other damaged parts too (I can't imagine sub-frame damage without something at the wheel end being damaged too)
The 11mm is probably at the tyre centreline, so the adjustment at the toe arm would be less, but I imagine the cam washers would only give 4 or 5mm (others might know better).
To be so far out, I would be looking for something installed incorrectly. I assume the toe arms were replaced at the same time as the bushes ?
Although the Alignment print out shows the camber in tolerance, it ought to be far closer each side to the 1 degr nominal spec & is easily adjusted by the cam washer on the left hand side top hub bush & will change the toe an amount too.
When I replaced all the bushes & toe arms on our car last year, I marked all the cam washers before removal & replaced them back to the same setting. When the car was re-checked on a 4 wheel alignment machine, everything was back on nominal settings - without any adjustment required. Paul,
Post #612283 11th Nov 2021 10:52am
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
The camber also affects the toe.
If you set the camber on the left to the same as the right it might bring the toe in.
Post #612284 11th Nov 2021 10:59am
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Curious to know how the type of engine induction has anything to do with this! Laughing
Chris
Post #612288 11th Nov 2021 11:31am
Pawl
The suspension settings are slightly different between the different engine variants - probably due to the engine weights differing Paul,
Post #612290 11th Nov 2021 11:55am
DrRob
Nobody should be doing an alignment without first checking all bushes are not worn otherwise it's pointless.
Personally, I'd find a better specialist. I'm lucky that mine also does 4 wheel alignment on site and does it properly.
The suspension should be locked in Tight Tolerance Mode for the alignment or suspension will fight itself.
Quite a few around the West Mids. Oval Autos are rated. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #612298 11th Nov 2021 1:50pm
Markwood71
Hi Dr Rob,
bushes were checked when the rear lower arms were changed. will be taking it to another 4W tracking company tomorrow who i know have the kit to do it properly ( fingers crossed)
Hadn't thought about tight tolerance mode so will set that tomorrow before i take her in for tracking.
something about a damaged subframe just doesn't seem to ring true, as i would have thought there would have been more obvious issues with the rear. but then again, what do i know ! Welcome Rosie J - The Newer Kid on the Block
Post #612316 11th Nov 2021 4:07pm
Rudyard1
I can see from the pic that you have Landsail tyres on - mine came with them and I too wondered about poor tracking etc as they were wearing badly/inconsistently.
My Land Rover specialist checked, and advised that they are pretty crap tyres etc and I changed for a set of Scorpion M&S - no problem since - wearing consistently etc.
It may be the rubber?
Post #612747 15th Nov 2021 10:20pm
Markwood71
Markwood71 wrote:
Hi Dr Rob,
UPDATE-
Went to a Hunter approved Tracking garage. Explained the issues and they asked to re-track on their system to see for then selves. even worse on the rears. ( pictures to follow). They tried to adjust rear toe & camber but found both rear upper arms "un-adjustable due to corroded bolts) recommend 2 new rear upper arms, bolts washers & nuts.
4 hours labour later ( and a dremmel to remove the NSR bolts) all tracked and all within tolerance.
I "think"- when the rear lower arms were replaced, they forgot to mark the bolts ( Pawl- you were right......) and when i was told they car had been re tracked, they maybe forgot to tell the truth......
all in all though- jobs a good un' and she now feels much more glued to the road. Welcome Rosie J - The Newer Kid on the Block
Post #613785 25th Nov 2021 1:32pm
Markwood71
Before and after
Post #613786 25th Nov 2021 1:34pm
dhallworth
It's a great feeling seeing all of those boxes going green whilst they're tracking the car!
Post #613789 25th Nov 2021 2:19pm
DrRob
Brilliant news! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #613849 26th Nov 2021 9:20am
Pawl
Glad you're sorted! Paul,
Post #613852 26th Nov 2021 10:20am
