![]() | Home > Technical (L322) > Electrical gremlins ...please help !!!! |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
The body control unit needs to be programmed to your car mate so will need gap iid to make it work. That's probably going to be your next best move as those items that ain't working are very much bcu related |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
Hi, that sounds like itβs dropped itself into transport mode. Use diagnostics like the Gap IID Tool to check and remove transport mode, if it is actually that. ______________________________
Spilly1978 Member Since: 12 Nov 2021 Location: Wales Posts: 5 ![]() ![]() ![]() |
Thanks for that guys ..... another problem I forgot to mention was that the obd port doesn't seem to work ...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Two things, l doubt heavy rain caused your problems, flooding yes- heavy rain no. Particularly as you appear not to have found any water in the car. Have you checked all the carpets for water/ damp?
The rear lamp was half full of water ,,, immersing one of the bulbs .... would this not be enough to cause harm ? .
What would be the cheapest diagnostic tool to reset transport mode? I'm trying to sell my range π©.... baby forces sale and all that π |
Do all the external lights still work? Including brake lights. |
Yes all lights except interior work , |
Can't think of any reason why your rear light filling with water would cause your problems then. |
