![]() | Home > Technical (L322) > Trickle charge through tow bar plug |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7971 ![]() ![]() ![]() |
It’s in the site shop,
Or do you mean the bit on the car? I can’t help with that I’m afraid.
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
That's the one, thanks ![]() 2000 4.0 P38 HSE - 'Green Goblin' - Gone. Audi..Mini..BMW.. |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
I bought the 13 pin adaptor, really nicely made. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
I find it so easy, boosting the charge by this method |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Shame I cannot get any connectors for my NOCO because it's the 15000.
Can’t you get one and change for your needs?
I've made one up using a connector and some flex, on the charger end I have used two bolts through a piece of wood as power posts to connect the croc clips up.
Ah… things have moved on a bit then….
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3858 ![]() ![]() ![]() |
I made up this board so that I could use a charger with crocodile clips or my Ctek.
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 ![]() ![]() ![]() |
I just use a ctec charger via a 10a fuse the a 13 pin trailer plug and it works fine .. i plug it in if the RR is not going out for a couple of days also keeps the battery toped up so the FBH works when it gets cold enough for it to be needed . 2012 Black 4.4 TDV8
