![]() | Home > Technical (L322) > Disconnecting battery |
2010BlackL322 Member Since: 30 Oct 2021 Location: London Posts: 120 ![]() ![]() ![]() |
All, QQ
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Just take off the negative without the ignition on. Done mine a load of times, no issues.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Procedure is in the Workshop Manual which is in the WIKI... don't think it will set the alarm off but there is an explosive disconnect in there somewhere so you may lose a few fingers... |
thank you! Check out my YouTube channel https://youtu.be/UHBbLWZXw4A |
![]() Hmm... thanks Check out my YouTube channel https://youtu.be/UHBbLWZXw4A |
That's on the positive terminal and it's activated from a crash sensor so you'd need to be pretty dynamic with the terminal to trigger it. This is why we disconnect the earth, no danger there. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
I was just answering the question if there was a procedure to disconnect the battery....
