Home > Technical (L322) > 2010 L322 Glovebox Trim
tpeat12
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Evening All,
I'm looking for a bit of help relating to the glovebox on the 2010 model i've just purchased.
When you open the glovebox, the latch that catches it and prevents it from dropping to the lowest point (to access the fusebox) comes straight through the hole on the inner glovebox moulding. This results in the glovebox constantly dropping to its lowest position when there is any weight inside the glovebox. I can't find any reference to a part number, but it is as if there is a rubber grommet missing which results in the hole being ever so slightly too large. Could someone please let me know whether there should be a rubber grommet around this hole, or offer another explanation for why this might be happening.
Many thanks!
Post #613180 19th Nov 2021 7:35pm
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
Sorry I can’t help you with the part number but I’ve had the same issue on mine. The plastic hook that goes through the hole can be gently bent (leg of the hook) while it’s out of the hole (in its lowest position). Then guide it back into the hole. At least this worked on mine. Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #613287 21st Nov 2021 7:23am
tpeat12
Thanks Graham. I'll give it a go and maybe try softening it with some verryyyyy gentle heat.
Post #615405 8th Dec 2021 8:34pm
DrRob
Bend it back. Works a treat. Careful with heat. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #615406 8th Dec 2021 8:51pm
GGDR
+1 for bend it back
worked for me
. Cheers, Greg
Post #615431 9th Dec 2021 1:07am
And worked for me on several occasions... Thumbs Up
Post #615434 9th Dec 2021 1:17am
