![]() | Home > Technical (L322) > Changing gearbox - need coding? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Coding is only necessary with the 6-speed transmissions onwards, when the transmission ECU became integrated into the transmission.
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135 ![]() ![]() |
Hi
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3345 ![]() ![]() ![]() |
If you’re changing the whole gearbox then yes it’ll need coding to the car.
Hi
The module that will need coding it the black plastic one that is bolted directly to the mechatronics unit inside the sump.
Macnaughton1 Member Since: 29 Nov 2024 Location: Fife Posts: 3 ![]() ![]() |
I am in fife and having trouble coding a second hand tcm unit could you help ? |
Or would the gap tool code the 2nd hand one to it ? |
I did mine using my IID tool.
I have bought the tool mate I fitted second hand one then garage said no wanted all new parts is it easier if I fit a new tcm unit or will it still code with second hand fitted ? |
You can definitely flash a used TCM with the IID tool.
