![]() | Home > Maintenance & Mods (L405) > Seat refurb 4.4 heated/cooled seats . |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Its highly likely the seat back unit has failed causing the entire seat to stop working.
Graham4242 Member Since: 26 Sep 2021 Location: Dubai Posts: 41 ![]() ![]() ![]() |
I’d be very interested in this repair kit. My seat back doesn’t blow air (drivers side). I started following the powerful video and lifted up the lower leather centre section however I have additional pieces. That mould around the side.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
You will need to undo the 4 bolts that hold the seat down, Which makes it easier to remove the side covers, the seatback is pushed down after releasing the sides off the spline left/right.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Easy peasy to take the seat out of the car HOWEVER!!! Be careful NOT to scratch plastics or paintwork when lifting it out of the car... The drivers side seat is much easier to remove if you also remove the steering wheel... |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 111 ![]() ![]() ![]() |
My cock up , stuck in it 405 section and should of stuck it in 322 !!!!!, hopefully answers are relevant especially the repair kit , heater still doesn't work when just the base is on so I recon both elements have gone . |
If one peltier motor is compromised (even with an air leak) the whole seat will shut down... |
