![]() | Home > Technical (L322) > Adaptive Headlights & Cornering lights - standard? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
normally when you switch the headlights on they should 'dance' whilst they adjust then selves.... ... - .- -.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Not seen that so maybe need to have a poke around |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
As previously mentioned, they react to the steering input and turn into the corner. It is quite obvious when you are driving at night time especially on country lanes. On the L322 it is not the 'dance', I think the dance started with adaptive beam headlights. These are just swivelling headlight, which is good enough, was rare at its age, although citroen did that many decades earlier ![]() |
my 2008 L322 had these headlights and they do indeed 'dance'.... ... - .- -.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
Yep they definitely dance on my 2006 Range Rover 4.2 Supercharged 2006
We are talking about the specs and spec list of the 2011 model |
they dance or initialise on the 2010-2012 as well..
They don’t do that on mine at all. Yet the functions work just fine. |
Pysta Member Since: 05 Sep 2021 Location: Bra Posts: 24 ![]() ![]() ![]() |
Can confirm, they don't do the standard dance on my '11 neither. Compared to other cars I had with AFS, the cornering LED comes on too soon for no good reason (even at slight turns at standard speeds around 50km/h), and the xenon swivel is not too obvious - similar to VW, but very unlike to PSA/Ford who throw the lightbeam around as if you're out fox hunting. |
