Home > Maintenance & Mods (L322) > Oil Cooler / oil return leak running onto transmission pan?
damonky
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Hi All,
Sorry for my first post to be an ask for help, but here it goes.
Been a lurking in the forum for quite a while whilst I looked for my first range rover and a daily reader, Love the community.
I've just purchased my first range rover (2011 tdv8 4.4 Vogue) full service history, ~120k, 3 owners, seems like quite an honest car and drives well.
Picked up the car on Friday from a dealer after requesting a few things to be fixed, Control arms, little bit of paint etc. For peace of mind took it to a friends garage and stuck it on a ramp to check further underneath. At that point found dirty oil coming down the block. The dealer came to collect it, cleaned it up and inspected and said he suspected it to be old oil from the filter change, and that there shouldn't be any more.
Took her out for an hours drive today, mixed town, b roads and a bit of motorway. On coming home checked underneath and the oil is back. I suspect from reading here it is the oil cooler, however there seems to be seepage from the transmission oil pan.
I suspected its the oil cooler or the oil return. But concerned the belly pan might be more than runback?
I should clarify the dealer is more than cooperative to get it fixed.
However, I wanted to get your thoughts before I go back to them tomorrow, and anything else I could / should have done whilst there?
Thanks in advance! -----------------------------------
2011 4.4 TDV8 Vogue
Post #616930 19th Dec 2021 6:01pm
JayGee
Could be the oil cooler - check the coolant and coolant header for oil contamination. Or could be the oil cooler return pipe O ring. Both common problems on these engines.(and could be both). 2012 TDV8 Vogue (L322)
Post #616934 19th Dec 2021 6:40pm
damonky
Thanks JayGee, was literally adding the o-rings to the original post. ( wasn't there when you replied)
Do you think the oil on the transmission is likely to just be runback? Not new to issues ( many years of vw's etc) but still unfamiliar with longitude engines / transmissions.
D -----------------------------------
2011 4.4 TDV8 Vogue
Post #616936 19th Dec 2021 6:44pm
JayGee
The transmissions don’t typically suffer leaks but a transmission service should be on your list of to-do’s for a new L322 owner. 2012 TDV8 Vogue (L322)
Post #616938 19th Dec 2021 7:13pm
damonky
Will go back to the dealer in a mo. Vanstones in Cornwall seem to have serviced it in the past, and only 50 mins down the road, So will get it booked in for that transmission service, see if the dealer wants them to do the leaks at the same time.
Thanks JayGee, much appreciated. -----------------------------------
2011 4.4 TDV8 Vogue
Post #616940 19th Dec 2021 7:30pm
DrRob
I’d say that’s 99% oil cooler gaskets and the O rings. Get it back to them and request a new oil cooler is fitted. They can warp so just doing the gaskets risks a future leak. O rings = fit Viton ones. All in the Wiki under Engine section
https://www.fullfatrr.com/wiki/Main_Page
Who is the dealer/garage that it’s going back to? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #616947 19th Dec 2021 10:55pm
Dolphinboy
get the oil cooler and coolant bottle changed. Here is my bill. it was £600-700 + 7 hrs labour. I also had the transmission and diff oils done. you'll never need to worry again. mines been perfect since.
Post #616949 19th Dec 2021 11:53pm
Fox889
Looking at your mileage, it’s probably odds on to be the oil cooler, also, if the gearbox hasn’t been serviced then to be honest, it’s about time to do so. Whether you go for a mega flush or just an oil & filter change, the choice is yours. I had mine megaflushed in year one of ownership & oil & filter in year two, think I had a slight weep from the gearbox pan as well, so you can kill 2 birds with one stone!😀
You’ve got the best FFRR & the best community here, look forward to hearing more from you. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #616965 20th Dec 2021 9:29am
damonky
Thanks all for the replies and help. Made me smile this morning, community is half the fun of owning an iconic car for me.
Following the general advice here, bought with a good contingency for servicing and less expected events.
I will update my progress and some photos when i get a chance.
Thanks again
David -----------------------------------
2011 4.4 TDV8 Vogue
Post #616968 20th Dec 2021 9:53am
DrRob
Keep us posted Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #616980 20th Dec 2021 11:14am
