![]() | Home > Technical (L322) > L322 Key Turn does not crank |
paddylimbo Member Since: 08 Apr 2021 Location: SHeffield Posts: 6 ![]() ![]() ![]() |
HI
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35790 ![]() ![]() |
battery or loose connection to the battery? ... - .- -.
We have checkesd the battery and the RAC man checked it a couple of times we he looked at it so don't believe it is that, we have had it off and on since fitting the ne module as well, and doble checked it. |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
Another possible could be the gear selector inhibitor switch telling the ecu the car is in gear rather than park or neutral thereby preventing the starter motor operating. see thread here https://www.fullfatrr.com/forum/topic15665...r+selector |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
@NobbyC: yes, good point but I changed my XYZ switch and it made no difference. The car did think it was stuck in 3rd but soon cleared when the ignition switch button was installed. |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 79 ![]() ![]() ![]() |
Agree with potential inhibitor switch. I had that on a P38 years ago. You could try dropping it out of park and into neutral before cranking. L460 460e PHEV AB. Belgravia green.
Thanks Matt, tried it in neutral but no joy. so frustrating. |
Winkelried Member Since: 14 Aug 2016 Location: UR Posts: 7 ![]() ![]() ![]() |
I've had this issue several times. Mostly its low voltage or a battery on its last legs.
thanks for that will have another try with the battery off. |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 207 ![]() ![]() |
I had exactly the same symptoms not that long ago, removed the xyz switch, cleaned out the inside and bent the wire pins so they were making better contact then put it all back together and haven't had a single problem with starting since. |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1030 ![]() ![]() |
You can replace the ignition switch not do hard I did that on mine but it was the starter motor in the end.
