Home > Technical (L322) > 2010 3.6 TDV8 FBH Problem
RJPotts
I wasn't sure if my FBH heater was working so I've just tried the appropriate test on my IID tool. It gives an error message that it cannot complete, with the code E7, which I think is a generic GAP code.
I understand that sometimes the FBH can be reset by pulling its fuse for a few minutes. I dont have a handbook for the car but the fuse locations in the Wiki handbook don't show it so presumably its in the engine compartment fuse-box.
Can anyone confirm which fuse is for the FBH please? I have had a search on here and see when Stan asked about F19 & F3 it was answered that they were FBH but I just wanted to make sure.... is F13 also a candidate?
Or, might anyone have a list of all the engine compartment fuses please?
Many thanks in advance! 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #618030 30th Dec 2021 2:42pm
RJPotts
Just had a reply from a friend who works for an LR dealer........ It is 13.
(Just incase anyone with a similar query find this in the future)
Now to pull the fuse for a while & then try the test in the IID tool again..... 2010 Range Rover Autobiography TDV8 Santorini Black
Post #618033 30th Dec 2021 3:11pm
RJPotts
I left the fuse out for about 20 minutes then put it back in and tried the test in the IID again.
Same error, "Operation failed E7" when either trying the test or the fuel priming for the FBH.
There are no FBH related faults detected by the IID. I have the timed climate option on the screen and I do have a remote that came with the vehicle. The remote does turn on the fan but not the FBH (although its 12' here at the moment so I wouldn't have expected it to do so).
Can anyone point me towards the next steps in finding / fixing the issue please? 2010 Range Rover Autobiography TDV8 Santorini Black
Post #618038 30th Dec 2021 4:15pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
How about:
https://www.techwebasto.com/old/academy_da...age_13.htm
or
http://www.techwebasto.com/old/academy_dat...Faults.pdf
Your E7 fault I could not find.
Sad
Post #618045 30th Dec 2021 5:15pm
Sandyt
Also make sure your battery is fully charged as if it detects insufficient power it stops to keep enough to crank the engine from memory
Post #618048 30th Dec 2021 5:24pm
rjff
You may have tried this, but ISTR somewhere on here that doing a hard battery reset can resolve the problem.
Does the FBH start up fully when the engine starts from cold? AFAIK the upper air temp for operation is 16C, according to the WM. Mine is an 11my so may be a little different to your 10.
As Sandy says, if the battery voltage is too low,then the FBH stays off. Cheers
Richard
Gap IIDBT
Post #618052 30th Dec 2021 5:36pm
RJPotts
Thank-you all!
SpitfireS wrote:
How about:
or
Sad
I think the E7 is a generic GAP code, I've seen mention of it with other tests on Disco 3s.
That second link is quite interesting..... especially "The fuse must be removed with the engine running or within 60 seconds after the engine has been shut down". I haven't seen mention of the within 60 seconds before so will give it a try again tomorrow, thanks!
Thanks, unfortunately I don't know the history of the battery (It was only a couple of weeks ago that I picked up the car) so will dig out a meter when it's daylight.
I haven't seen any evidence of the FBH starting at all, at any temperature. If the temp is cold enough tomorrow I'll stick my head under the LH wheelarch & try the remote (after the fuse-reset within 60 seconds of the engine being shut down). If there's no luck I'll try the battery reset.
Thanks!
Richard 2010 Range Rover Autobiography TDV8 Santorini Black
Post #618055 30th Dec 2021 6:01pm
SpitfireS
Now that I think about it:
What happens when you, after a cold start, ask for all the heat there is to ask for, everything at max?
The FBH also assists with extra heat when the (diesel) engine doesn't supply it (yet or at all)
Maybe you will get another error code that might help?
Question
Post #618060 30th Dec 2021 6:16pm
RJPotts
Good question........ I'll give that a go in the morning & then have a look for fault codes.
Thanks again!
Post #618061 30th Dec 2021 6:20pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
No fault codes come up under FBH in IID?
Do you get any live data?
Post #618066 30th Dec 2021 8:04pm
Gsxr1250dave
With the gap tool just do a vehicle reset that will clear any lock out the fbh has stored in it, they will lock out after x3 failed attempts to run be it from low fuel to other reasons.
Post #618072 30th Dec 2021 8:58pm
RJPotts
Nope, no FBH related faults.
I needed to go somewhere this evening & remembered that the 753 menu show battery voltage;
11.5....... that was with ignition on but engine not running. Is 11.5 low enough to prevent the FBH firing?
Ah, I knew about the reset function but not that it would clear FBH lockouts. Do you happen to know what else it resets / clears?
Cheers
Post #618073 30th Dec 2021 9:16pm
JNC
11.5 is low. I would check FBH live data.
Post #618075 30th Dec 2021 9:59pm
RJPotts
Just been out to the car with a meter.
I get 11.85 across the battery terminals. I've used the remote & straight away could hear a fan, will nip out in 10 minutes to see if there's anything from the FBH exhaust.
Edit: 10 minutes later nothing from the FBH and its exhaust was cold.
I get no section in the IID live values for AHCM....... can anyone with a 3.6 TDV8 & IID confirm they get a AHCM section in the IID live values? 2010 Range Rover Autobiography TDV8 Santorini Black
Post #618123 31st Dec 2021 9:45am
