![]() | Home > Technical (L322) > Happy New GEAR!! Is it a healthy year for my gearbox? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1022 ![]() ![]() |
Happy New Year!
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169 ![]() ![]() ![]() |
Thanks Phil for sharing your wisdom regarding the ATF. Learned now that i did something right for the wrong reason |
I’m not sure if it might be worth trying the BMW forums in the search of more information, as the same transmission (BMW call it the A5S360R/A5S390R) was used in E53 (X5), E83 (X3), E46 (3-series) & E39 (5-series).
Thnak you again Phil |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 ![]() ![]() ![]() |
hi, I can tell you with certainty, that the springs of the accumulators, for l322 are not the same they are of different sizes, also specifies it on the sonnax website, I am updating the valve group with sonnax, and I must say that the new pistons operated by the soleinoids , they are made really well, when the gearbox is about to yield, you realize, in part at the minimum that there is something crawling, such as finished brake pads. |
Hello Madcima, thanks for your clear statement that these accumulator springs should be of different sizes. That should mean that for my valve body it all could be as it should be. I couldn't find anything of documentation or website info on this. You say it is on the Sonnax website but I am not able to find it. Do you have a link to this info?
https://www.sonnax.com/tech_resources/295-...tification here is the link, i'm in emilia romagna |
Thanks madcima! |
wait, I fixed it on my own, I am not a repair shop! I can tell you that the springs are of two types of length, 2 long and 2 short at least in mine it was like this, instead the repair manual says that they are all 4 the same.
O wow, that's high tech! Well done |
I would like to post photos but it won't let me do it |
first hit button "choose Photos" just on the left side under the text box. After that you can click on the "upload" button on the right side. After that you have to click on the uploaded photo to insert into your text box. That way it should do it. |
