![]() | Home > Technical (L322) > Help identifying vibration noise |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 773 ![]() ![]() |
Sounds like the gearbox heat shield, easy fix if it is |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 62 ![]() ![]() ![]() |
OP I have exactly the same noise that I have been unable to fix either - what is it about the heat shield that typically goes wrong? |
The shield can crack but it could also just be a loose/stripped mounting screw as its only held on with 6 (I think) bolts.
Oilee Member Since: 24 Feb 2021 Location: tadworth, Surrey Posts: 17 ![]() ![]() ![]() |
Sounds more like there is a grizzly bear stuck under there. 2003 4.4 V8 Vogue. Oslo Blue.
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
@cass; thanks for the tip and your explanation would make perfect sense. There is actually a small misting of oil around the gear box after they did a service 2 years ago. it´s not enough to do anything about but they guy who did it probably did not know what he was doing....
