![]() | Home > Maintenance & Mods (L322) > Mot fail |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
That's not good, I'd get quotes for the welding before anything else, make sure it's worthwhile, to do it properly is an awful lot of work...... |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
I would agree with Haylands - get a quote for the welding before you do anything else. |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Pete
One thing that bugs me is this. What's peoples opinions on using these parts. Going by the top one given 411 people have bought these, are they recommended or just an easy "pass an mot" setup.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1040 ![]() ![]() |
Every cloud has a silver lining urs is B king |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
At these prices I just look at them as a service item. I reckon that they are probably all made in the same factory anyhow. L322 3.6 TDV8 Vogue. 07MY
Gsxr dave
Delphi should be OK they are an OEM for Land Rover...
Pete
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
Yikes, is that your 4.2?
David
If you’re thinking of keeping it for the long term then I guess doing both sides makes sense as it’ll likely not need doing again.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2260 ![]() ![]() ![]() |
The rear corrosion is it jus the rear subframe? If so can you get a used one form a newer car? This is a real weak point in these I looked at a good 5 or 6 of similar ages before I found my 07 most of them looked like they’d been parked in salt water with dodgy mots Current stable:
Am i missing something? It states its a RRS on the MOT failure... |
