Home > Technical (L322) > Handbrake MOT Failure
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
It seems there are right and wrong ways for testing the RR handbrake ('11 TDV8) during an MOT test.
Assuming the tester used the correct method, how do I tell whether the brake shoes need replacing or just adjusting?
Thanks.
Post #620341 17th Jan 2022 9:29pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Stop on a steep hill. Shift into neutral and apply parking brake. If the car holds then parking brake is fine.
Post #620343 17th Jan 2022 9:48pm
If you are worried about your handbrake operation it would be worth taking off the rear drum/ discs and cleaning out all the crud that collects in there. The crud tends to act as lubrication between the shoes and the drum greatly reducing the handbrakes efficiency. While you are in there it is also worth emery papering the surface of the shoes to remove any glazing. Thumbs Up
Then as above try it out on a decent hill.
Post #620345 17th Jan 2022 10:06pm
Mike Edwards
I'm not worried about the operation, I just need it to work long enough to pass the MOT. Or at least have the MOT place assure me they tested it the correct way.
Post #620868 21st Jan 2022 11:40pm
