Home > Technical (L322) > L322 2011 4.4 V8 front heater not working
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
Help please. I've used an icarsoft to scan for codes but nothing relates to my issue. Is this a good tool to use?
The rear blowers work
The front switches light up but no sound, even on max from the heater
If I lift the bonnet and turn the fans on full, I can feel air being blown under the removable cover and if removed, you can feel it blowing straight into your face. Is this right?
Could this be a fuse? If so, which one? I think I've read about it being a 40amp one.
Grateful for any help.
Post #620754 21st Jan 2022 11:29am
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Sounds like your heater blower has packed in if it doesn’t work on any of the speed settings, I’ve done a post on how I changed mine but before I’d remove the pollen filter housing, turn car on and start the fans if there working you will see them spinning if not spinning it’s time to change unfortunately 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #620767 21st Jan 2022 1:51pm
stuartj9
Cheers for the reply mate. Appreciate it.
Sounds like your right but will check this weekend/early next week.
Being a little lazy, where is the pollen filter accessed from? I'm guessing the centre of the engine, towards where the faulty part is?
Post #620775 21st Jan 2022 2:21pm
Furnitureman
Open bonnet the pollen filter is at the back there are two 13mm bolts holding it in place it’s a big bit of kit when it comes out 2012 Range Rover Westminster 4.4 TDV8
Post #620832 21st Jan 2022 6:39pm
Rambles
When I was putting my MY11 in for a blower motor replacement, there were other L322s also getting new blower motors.
Seems it is not uncommon that the bearings seize up
And then no blow
New blower motor is a slightly revised design I am told
Could be that it is just your FSR that is blown however, which is a cheaper job to replace than a blower motor
Post #620837 21st Jan 2022 7:20pm
stuartj9
How would I know which one it is without doing one, it not being that and then the other one? I don't think you're going to be able to tell me lol
Post #620839 21st Jan 2022 7:47pm
Rambles
My blower motor was on the way out for a while. It blew a few FSRs and the HVAC control module before it finally gave up.
I could hear the bearings chirping - but originally put it down to the accessory belt.
If you replace the blower motor, I would replace the FSR in any event.
So whatever you choose to do, sounds like a new FSR will be needed at some point !
Post #620848 21st Jan 2022 8:36pm
stuartj9
I've just thought and it might be a coincidence, there's been a squeak coming from one of the belts under the bonnet. Could this have anything to do with it?
Is there a specific fsr and blower I need? I've read about upgraded ones.
Cheers
Post #620850 21st Jan 2022 8:50pm
Rambles
If the squeak / chirping is still happening after your blower motor is stopped, then it could be belt and / or idler pullies
If squeaking / chirping stopped when blower motor stopped......then the squeak could have been the bearings
Only one option for blower motor and FSR (final stage resistor)
Am confused though when you say blower motor does seem to produce output but somehow in the wrong direction and not through the blenders etc.....but backwards through the pollen filter .....
Post #620851 21st Jan 2022 8:58pm
stuartj9
Update - I've took out the pollen filter (see pictures) but I can't see any motors. Am I missing something? I've had the blowers off and on full, without the pollen filter. Still nothing.
Post #621363 25th Jan 2022 5:07pm
stuartj9
Post #621364 25th Jan 2022 5:08pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi stuartj9,
I’m in a similar boat and have ordered a new blower and fsr from advanced factors… about £110 total.
whether and family permitting it’s a job for this weekend.
When I took my pollen filter unit out I could see my fan from both sides. I believe you need the fan to be set to on for the flaps to open so you can see them. They are the air recirculation flaps I think…
Also you took the pollen filter out. If you undo the two bolts to the plastic housing the entire unit comes out. You’ll get a better look at the fans then.
It’s odd that you felt air blowing at your face before in the engine bay… the only fans blowing air are designed to blow air into the car and not the other direction. Unless you felt the air from your engine fan??? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #621373 25th Jan 2022 6:17pm
Ffrr-lover
Have a look at this post from me… and the messages from furnatureman who has tackled replacing the blower. I’ll be updating my progress here…
https://www.fullfatrr.com/forum/topic62278.html Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #621374 25th Jan 2022 6:22pm
stuartj9
Cheers mate. I think the air/blow is coming from the fan by the radiator, so nothing to do with the heating.
I'll keep watching your post. A little confused though. Can you cut under the dash to get the fan out that way?
Post #621400 25th Jan 2022 9:23pm
