![]() | Home > Technical (L322) > Help needed - big coolant leak |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
It’s a 2003 car, I’d order a full set of replacement hoses and just replace them all. They don’t cost much. When the system goes under pressure it will just find the next weakest point. Also if you don’t know when the waterpump was last done i would change that and the thermostat as well. Buy proper sets including the o rings etc.
Paulo_G Member Since: 16 Jan 2022 Location: Stratford on Avon Posts: 6 ![]() ![]() |
I’ll do that, get some new pipes on order. Not sure when the water pump was changed but there’s tons of history with the car so will go through that and find out. Problem is I’ll need to get to work on Monday, so very much hoping I can find the problem and implement a temporary repair to get me through.
Ouch that might be a challenge to get the parts tomorrow for a decent price and quality. I’m no fan of what euro car parts would carry. Good luck. |
So, done some investigation work this evening with a mate by torchlight, turns out water is gushing down the block from the water pump. So water pump and gasket replacement it is then. Highly doubt its something the seller could have covered up, it gushes out from a cold start, so would definitely have noticed when I took it for a test drive.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
To replace the water pump you'll need to create some access space first. Remove the air filter duct, viscous fan (nut unscrews clockwise as you look towards the engine) and fan shroud. I would absolutely change the thermostat, as well as the cross over pipe o-rings that connect to the pump.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
Make sure you get the best quality or OEM pump you can. I got an American Parts or some such rubbish which dumped me on New Years eve 300 miles from home! went for a Hella next and much better. |
