![]() | Home > Technical (L322) > Adaptive Cruise and DSC |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7976 ![]() ![]() ![]() |
There is a light on the dashboard to show the cruise is on…. Sure it’s not that? Simple things first and all that….
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 261 ![]() ![]() ![]() |
Err yes, the green cruise light was on as well. 2011MY 4.4TDV8 Autobiography Baltic Blue
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
DSC or ACC in follow mode? |
Both lights were on continuously whether clear road or following. 2011MY 4.4TDV8 Autobiography Baltic Blue
It's certainly not normal, indeed if DSC was switched off prior to setting CC/ACC then DSC gets switched back on. I would try switching DSC off then selecting ACC to see what happens but if still malfunctioning then I would disconnect the battery for a few seconds which will cause all ecus to cold start. |
Thanks GraemeS, I’ll give your suggestions a go. 2011MY 4.4TDV8 Autobiography Baltic Blue
Ignore my post! A classic case of 'Should have gone to Specsavers' - it was the amber follow mode light, not DSC ! 2011MY 4.4TDV8 Autobiography Baltic Blue
I meant to try mine the other day to check which lights come up where….. least you know now…
