![]() | Home > Maintenance & Mods (L405) > Choice of oil for sdv8 |
| Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119
If the Petronas oil is a Fully Synthetic Engine Oil and says it is ACEA C1 Low SAPS Ford WSS-M2C934 then you can safely use it. If it doesn’t you shouldn’t use it. |
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
As above. If it meets the spec, it'll be fine. Kev
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Opie oils include it in their options for the 4.4 tdV8, but are showing it out of stock.
| 154JON Member Since: 31 Mar 2019 Location: Essex Posts: 133
Morning
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1417
If it meets the specifications required it doesn't matter what name is on the label, thats just preference or marketing... |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I use Morris of Shrewsbury's version that meets the spec |
Just ordered 20ltrs from Smith and Allan on Kev Watkins recommendation. |
I've been using S&A for a few years. Good stuff, meets the spec and great value |
