Home > Technical (L322) > Suspension Fault C1A18-64 and C1130-66
jjfang
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
My truck is producing two suspension fault codes, 2010 Range Rover with 105k miles.
C1A18-64 (AF) Pressure increases too rapid when filling reservoir - Algorithm based failure - signal plausibility failure
C1130-66 (2C) Air spring air supply - Algorithm based failure - signal has too many transition/events
It has been producing the C1130-66 (2C) code on and off for about a month, usually doesn't come back for a week or two at a time, Ive been trying to track the leak. But this new code comes back immediately after clearing with the IID, its been fairly cold here in Chicago being in the single digits and tonight dropping to -8 degree F. The truck does lower and raise but when raising it raises very slowly. Im thinking this is a front valve block failure any other thoughts?
Post #621427 26th Jan 2022 3:29am
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
Getting to the route cause of a suspension fault can be a real pain. There is lots of good advice out there and I am by no means an expert but I had slow rising on my car. A compressor rebuild kit from 4x4 air seals has the suspension rising up far quicker so I can heartily recommend it. I’ve done the same on a mates car and it’s had the same effect. Job took 2 hours from start to finish. As for the rest of the symptoms three other mates are having similar issues and were going through each of the valve blocks, single one attached to the compressor and the triple ones front and back.
My overall felling is very much worth getting the compressor rebuild kit AND the full valve block kit and going through all of it one by one. All jobs are very doable plus I’ve found unbelievable gunk in the compressor that is probably down stream and preventing valves opening/closing/fully sealing.
Once you have all seals done throughout the whole car if you do get a dropped car as least you won’t be thinking valve or bag. Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #621725 29th Jan 2022 8:47am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Could be your rear valve block not operating correctly. Do a web search on the first fault code and you'll get quite a few hits / suggestions to try.
Theory being the rear valve block doesn't open to fill the reservoir so the pressure builds too rapidly. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #621736 29th Jan 2022 10:08am
