Home > Technical (L322) > TDV8 Idling Rough |
Could it be a faulty MAF? |
7th Jun 2011 10:00pm |
Trev Member Since: 20 Jan 2011 Location: Aberdeen Posts: 3 |
Hi , thanks for getting back to me . I took the car back to the garage yesterday and got it plugged back onto the computer. The only fault that is coming up is the EGR valve.Looks like I will have to get it booked in next week to try to get to the bottom of it. Cheers. |
8th Jun 2011 1:49pm |
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 |
TDV8 rough idle is a known issue by Land Rover, it has taken me nearly two years to fix the issue with several visits to dealer. Finally a software fix was developed and should have corrected the problem. Make sure your dealer down loads the update and installs it for you. 2018 Range Rover Autobiography
12th Jun 2011 12:54am |
Steve L Member Since: 07 Sep 2011 Location: Cape Town Posts: 1 |
I have spoken to my local agents and they are adamant that they have the latest software downloaded and installed on the car. They have also replaced the engine mountings. In my particular case, the rough idle is only when the car is in 'Drive' and I am holding it stationary with the brakes. In 'Park' it idles perfectly smoothly. Any ideas?? Cheers |
7th Sep 2011 10:30am |
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 38 |
*Kick*
8th Apr 2014 9:32pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
rough idle under load would indicate injector problem did they check injector readings |
9th Apr 2014 6:38am |
You kind of answered your question Yourself would advise to take a look at h/p sensor but its quite difficult to access so dealer time |
9th Apr 2014 6:40am |
a clean out ? you need to diagnose the fault and replace faulty part cleaning is not going to fix an EGR in tdv8 |
9th Apr 2014 6:43am |
yes, we did check injector readings, but ofcourse the car ran fine when we were reading... All injector values seemed fine at that moment. '17 Range Rover 5.0 Supercharged AB (Sold) '16 Range Rover SDv8 AB (Sold) '15 Range Rover SDv8 Vogue (Sold) '13 Range Rover SDv8 Vogue (Sold) '12 Range Rover TDv8 (Sold) '10 Range Rover 5.0 Supercharged '03 BMW E39 M5 '01 BMW E46 M3 |
9th Apr 2014 10:09am |
I'm not fond of random replacing stuff and hope the problem goes away. It gives both faults on rail pressure sensor and fuel pressure sensor (I believe fault code 089 and 190), so the car just doesnt get enough fuel every now and then. I don't think the sensors are faulty... Problem is the car can drive for 100 km without any problems. I'd rather just see it stopping completely, that would make fixing a lot easier. '17 Range Rover 5.0 Supercharged AB (Sold) '16 Range Rover SDv8 AB (Sold) '15 Range Rover SDv8 Vogue (Sold) '13 Range Rover SDv8 Vogue (Sold) '12 Range Rover TDv8 (Sold) '10 Range Rover 5.0 Supercharged '03 BMW E39 M5 '01 BMW E46 M3 |
9th Apr 2014 10:12am |
