Mine is a 4.4 tdV8 L322, but the L405 is very similar.
Mine was the old design and replaced under warranty with the later L405 type , when it stuck and caused the car to go into restricted performance every time I got the revs up to 2,500 rpm.
It’s a fairly easy job if you get the front of the car raised and work from underneath., although it can be seen from above if you look down to the right behind the radiator.
 | | Click image to enlarge |
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
