Home > Maintenance & Mods (L322) > 2007 rear wheel getting warm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
Wheel bearing?
8th Mar 2022 9:53am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
could it be rust under the shims that the pads slide on? |
8th Mar 2022 12:36pm |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
Were the caliper slide pins moving ok? The upper pin has a rubber boot part way down that can swell and cause the pin to jam 2011 TDV8 Vogue SE |
8th Mar 2022 1:02pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
I'd still put money on it being a sticky calliper.
8th Mar 2022 1:48pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
The wheel bearing would have to be close to collapse to generate enough friction to warm the wheel.
8th Mar 2022 2:45pm |
tdv8rr2007 Member Since: 26 Oct 2021 Location: Yorkshire Posts: 13 |
All valid points thank you! However both pins were free as anything, and i always take the shims off and thoroughly clean under them them when changing pads.
8th Mar 2022 2:47pm |
Ah, forget the wheel bearing then….
8th Mar 2022 3:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
If you don’t find anything else it could be the flexible brake hose at fault. They have been known to deteriorate internally and end up acting as a non return valve. |
8th Mar 2022 3:46pm |
If i remember correctly the rears were done as a dealer recall approx. 5 years ago. I would be disappointed if genuine parts had failed in that time although its not impossible. Will stick a caliper on it and see if that cures it if not then I agree that pipe is indeed suspect. |
8th Mar 2022 4:26pm |
If you see any black bits in the bled brake fluid, that would indicate if the flexi hose was breaking down.
8th Mar 2022 8:31pm |
Good point Mike! Have parked the Rangie up till the weekend till i can get a caliper. Will be interesting to see what comes out. |
8th Mar 2022 8:37pm |
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 |
What was the outcome??? |
18th May 2022 7:50am |
