Home > Maintenance & Mods (L405) > Minimum Disc Thickness?
Rob99
My wear indicator light has come on for my front brakes and I wanted to check the disc thickness to see if I needed new discs at the same time as the pads.
When I look at the L405 workshop manual it tells me the discs were 34mm when new but doesn't say what the minimum thickness should be, only that it is marked on the disc (helpful - not!)
Anybody know what the minimum thickness should be? I have the high performance brakes with 6-pot calipers.
Cheers
Rob 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #623407 12th Feb 2022 1:28pm
Kot
You are allowed 2mm wear, so if yours were 34mm new, you are allowed 32mm.
380mm front brakes
Front 380mm ventilated 34mm max wear 32mm
Rear 365mm ventilated 25mm max wear 23mm
363mm front brakes
Front 363mm ventilated 33mm max wear 31mm
rear 350mm ventilated 25mm max wear 23mm
349mm front brakes
front 349mm ventilated 34mm max wear 32mm
rear 325mm ventilated 25mm -max wear 23mm 2018 SE SDV8 4.4 Byron Blue
Post #623445 12th Feb 2022 4:00pm
Rob99
Thanks Thumbs Up
Do they measure disc thickness on an MOT? 2021 D350 Fifty Edition - Carpathian Grey
Post #623446 12th Feb 2022 4:09pm
Kot
I dont know, they will test the brakes if they pass, they pass but if your pad thickness alarm is on thats another matter Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #623447 12th Feb 2022 4:13pm
Kot
But the dealers are keen to check it for you Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter for obvious reasons Rolling with laughter Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #623448 12th Feb 2022 4:14pm
knwatkins
Minimum disc thickness for the front is 31mm
Minimum disc thickness for the rear is 22mm
So maximum wear of 3mm is permissible.
That's according to the Delphi and Brembo spec sheets...
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #623612 13th Feb 2022 9:37pm
Kot
For MY18 JLR spec
https://www.fullfatrr.com/gallery/albums/u...0Specs.pdf
But in the 2016 WS manual it doesn't actually give the wear spec but it does say its marked on the discs somewhere. 2018 SE SDV8 4.4 Byron Blue
Post #623629 13th Feb 2022 10:38pm
knwatkins
Yes, it's marked on the outside edge Thumbs Up Kev
Post #623637 13th Feb 2022 11:07pm
Rob99
Thanks all.
Mine's a MY17 (67plate) but does seem like the consensus is that 31mm is the minimum.
Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
Post #623674 14th Feb 2022 3:13pm
