![]() | Home > Technical (L322) > Budgie in my engine |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 847 ![]() ![]() |
If chirping not affected by rpm, are you sure it is accessory belt / pulleys ?
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3347 ![]() ![]() ![]() |
It's coming from the front of the engine low down on the left and if I spray WD40 down there it stops. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Did you change the one top left as you look at the engine?
Mine was |
No idea as the garage did it and assumed they changed the lot. 2012 TDV8 Vogue (L322) |
Should be on your invoice to cross check part number Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13deg this morning and no noise on startup. 2012 TDV8 Vogue (L322) |
Think it's oil on the belt dripped down from spilling it while topping up without a funnel. Not easy to clean as it's so inaccessible. I can see a possible method with a stick and a pad soaked in brake cleaner to hold under the ribbed part as it's moving but it's not ideal and there's a ( big) risk it would slip and.... 2012 TDV8 Vogue (L322) |
Gave it a good squirt in detergent from a hand sprayer while it was running just now. Definitely a belt contamination issue as the chirp is exactly in time with a white marking on the belt and it goes quiet when the detergent was first squirted on ribbed side. May need a few applications to cure it. 2012 TDV8 Vogue (L322) |
