![]() | Home > Technical (L322) > Updated: Does a knackered BT module screw the whole system? |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Yes, when mine went the whole AV system wouldn't turn on |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Thank you |
You can get a fibre optic joiner thing on eBay pretty cheap which allows you to do away with the Bluetooth module if you want to test the theory. |
Ordered |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 816 ![]() ![]() ![]() |
Dont expect it to cure the issue pal |
What do you think the issue is?
Could be anything pal , over complex system that LR insisted on using ,makes it unreliable and difficult to nigh impossible to diagnose , mine is doing much the same but nothing i tried with the optics made a difference, im ripping mine out and fitting android from scratch, i hope the loop works for you , by the way you can try looping it to test it , youtube ' range rover atereo fix , its easy to try and free |
I have just been out and re fitted the BT module....nothing.
Yay , result , at least you know for sure pal , order a BT unit now ?? |
I probably will, but I want to make sure that there is no more cracking when I fit the new bypass loop, which should come tomorrow (Amazon deliveries in France are not reliable).
Just to update in case it ever helps anyone, I received the fibre optic loop bypass thing today.
Great stuff 👏 |
