Home > Technical (L322) > Deployable side step
Whussain5
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
Hi all,
So I have an issue with the drivers side deployable step on my 2010 L322, it just doesn't seem to be working. The passenger one seems to be working fine when unlocking the car and when opening the doors.
Can someone advise what things I should be checking in order to diagnose the issue and possible solutions to this issue.
Thanks
Post #624539 23rd Feb 2022 5:16pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
On mine, I have them greased every service. Apparently they can get clogged and jammed with dirt.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #624546 23rd Feb 2022 6:02pm
Whussain5
Brilliant thanks Ivan I'll take it off tomorrow and grease it up to see if that helps
Thanks
Post #624547 23rd Feb 2022 6:05pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
It will work for longer if it`s clean, putting a lot of grease can hold more dirt? using a good CRC silicone spray and not WD40 will help?
Post #624595 23rd Feb 2022 11:04pm
Whussain5
I shall do that. Thanks for the advice
Post #624597 23rd Feb 2022 11:07pm
Adrian 15
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I had the same issue a few days ago, I gave the hinges a good flush with WD40 and they work again and I intend give them a good grease up or maybe looking at fitting a grease nipple. Range Rover Vogue SE 4.4 TDV8
Post #624616 24th Feb 2022 9:34am
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I think fitting grease nipples would be a great way of sorting the lubrication issues with these. Filling them with grease would help keep the dirt and corrosion out.
I've seen a video of someone fitting them to something else before, but I'm not brave enough to do them myself without some guidance, so if you do fit them, can you document it please?! 2010 4.4 TDV8 Vogue SE
Post #624723 25th Feb 2022 1:55pm
cass
my experience of the brackets on these suggests that they're not particularly strong and the design doesn't look as if its nipple friendly.
I've got a broken bracket if anyone wants one to play with before attacking their own good one?
Post #624728 25th Feb 2022 3:27pm
Kot
Try this
https://wd40.co.uk/product/high-performance-white-lithium-grease/ 2018 SE SDV8 4.4 Byron Blue
Post #624731 25th Feb 2022 4:39pm
Adrian 15
When I get a chance I will have a look about the possibility of grease nipples, if brackets are really unfriendly you could tig a nut or something similar to mount a nipple or even drilling a hole half way through the pin and then drilling again at right angles.
I will have a look unless someone beats me to it.
I like the idea of WD40 grease ( other makes available I’m sure), great for flushing the muck out. Range Rover Vogue SE 4.4 TDV8
Post #624891 27th Feb 2022 11:54am
