![]() | Home > Technical (L322) > Help me with my dilemma |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1865 ![]() ![]() |
Is the actuator moving freely, seized, or tight to move? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6834 ![]() ![]() ![]() |
They have said the actuator linkage is moving freely, so I’m assuming it’s the bit the linkage connects to.
Just to follow up on this, they said the linkage was moving freely but they suspect that the actuator itself is faulty, so they has suggested replacing the entire turbo. I did ask if if was possible to replace just the actuator but they advised against it, so I'm still stuck in my dilemma............ Got - 2017 SDV8 Autobiography in Loire Blue
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2718 ![]() ![]() ![]() |
Tough one Alan, as you say , probably 25% of the cars worth . I wouldn't , others may differ. even fixed, it's still a £5kish car.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3347 ![]() ![]() ![]() |
Not much of a dilemma from my POV - no point sinking £1k into it if you are not going to keep it and it's not worth that much even if fully working. Offer it up on here or trade it in and hope for the best. Not probably the best time to buy a used car but if you want an L405 you are not buying on a budget so just cut your losses and move on. 2012 TDV8 Vogue (L322) |
Thanks for your opinions guys, they do tend to agree with my thoughts right now.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
most actuators can be refurbed nowadays , can i assume the FF ones cannot then ? |
Well the garage said it was as much labour to get the actuator off, so they suggested it was best to do the turbo while it was off.
mercedes tell car owners the same thing but i have changed several actuators without any bothers in about 25 mins , im just saying pal . . . . . |
I hear you and I'd love that to be the case and if you can change one on a FF in less than 30 minutes, I'll pay your fare up to Glasgow to do it for me |
