![]() | Home > Technical (L322) > Noisy Fan noise from the Battery compartment? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Sounds like the Fuel Burning Heater to me. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Philclemo Member Since: 07 Feb 2022 Location: Lancashire Posts: 17 ![]() ![]() ![]() |
Ooh, please expand. RR Westminster 2012 4.4 TDV8 Orkney Grey
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Sounds like that to me too. A bit like a jet taking off. The diesels have a fuel burning heater, in the wheel arch under the battery area. It comes on to help heat the coolant up under certain circumstances, as a Diesel engine doesn’t give out as much heat as a petrol one, generally speaking.
It’s in the passenger wheel arch, behind the liner….
Thanks guys. I'll take a look at the Wiki (I do forget about TBH).
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
There is also a fan on the ECU bolted to the battery, these fans can fail and make an almighty noise on the way out, very different sound to the FBH. Christian.
Thanks Caesium.
It should not be excessively noisy, its just a reasonably deep fan noise, accompanied sometimes by a little smoke and the smell of diesel. Christian.
Yes, I wouldn't expect it to be too noisy it being the car it is but it does howl and it's audible in the cabin.
You can def hear it running, and has already been said, the exhaust for it is down where the front mudflap is or would go, and it will smoke from there occasionally.
