Home > Technical (L322) > CV Joint Grease - How much of it?
dhallworth
I’m replacing both the inner and outer gator on both rear driveshafts as one had been bodged in the past.
I bought two GKN kits from Island 4x4. However, each kit has come with a mega amount of grease. There’s about 6 sachets per kit.
I’m guessing I don’t need it all as it’ll just spill out and make a right old mess.
Does anyone know what the right amount to put in is after I’ve flushed and cleaned both joints?
There’s 5 sachets of Genuine Grease for CV joints and 2 sachets of Optimol. The Optimal feels heavier. 🤷🏻‍♂️
Thanks
Post #627555 1st Apr 2022 7:02pm
dhallworth
Right:
The 2 heavier packs of grease (Optimol MS139G) are used on the Outer joint.
The 5 packs of lighter grease (MS141G) are used on the bigger inboard joint. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #627561 1st Apr 2022 7:50pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Only JLR would use different grease for each side of a drive shaft. Rolling Eyes
Post #627677 3rd Apr 2022 8:03pm
dhallworth
Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #627678 3rd Apr 2022 8:38pm
JCW
I’m replacing the outer CV boot (front driver side) on my L322 after it was damaged by Bourton LR when replacing the suspension arms & ball joints (these things happen but they flatly denied doing this despite the obviously fresh dint in the clip where the split is and CV grease leaking out a matter of a few miles afterwards yet no call from them whilst doing the job that it was already leaking, that logic was lost on them when I went back - shame as I’ve used them a few times previously without issues…).
I have the genuine GKN boot kit; outer & inner boots / clips & several packs of CV grease - I’m only replacing the outer boot. Ref. David’s post above, do I take it I use two sachets of the supplied grease in the joint?
Thanks Thumbs Up Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #685780 16th Feb 2024 3:15pm
