![]() | Home > Maintenance & Mods (L322) > Rear wiper and lower tail gate latch not catching |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
It’s in the W.M. if you need more detail.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
To just change the blade switch ignition on to run then switch rear wiper on, when arm is in mid position switch ignition off you can then lift arm to change blade, when its done ignition back on rear wiper off ignition off. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Lift the tailgate when the wiper is mid position and it will stop - may take a few attempts to catch it. 2012 TDV8 Vogue (L322) |
Lifting tail gate didnt stop it on the 04 or the 08 I have now, its a switch it off job. |
