![]() | Home > Maintenance & Mods (L322) > Restricted performance |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1361 ![]() ![]() ![]() |
First check on these engines are the 4 rubber manifold inlet hoses. Should be clean and dry. If they have black soot on them they will be leaking. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
Which garage are you using ? I’m close to Winchester so can recommend a decent place for you.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
There doesn’t appear to be a link between the work you’ve had done & the problems you’re now having, apart from the exhaust sensors (why?).
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
I used to get restricted performance on start up or occasionally on a drive but the car drove like normal turned out a new battery fixed it as the old one was struggling, may be worth a check 2012 Range Rover Westminster 4.4 TDV8
A one post wonder...never to be seen again |
