Home > In Car Electronics (L322) > Logic7 HD Sound system |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
In my few years owning range rovers… I did not know this one!
8th May 2022 4:22pm |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 77 |
Yes, that’s it. Mine was turned up to maximum setting. I suppose that means that I would have to go at 130 mph to hear the sound in all its glory!
8th May 2022 4:26pm |
I meant to say you can also adjust the phone and satnav volume with that menu |
8th May 2022 4:27pm |
I’ve never had issues with the volume or sound quality.
8th May 2022 4:41pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
The AVC isn’t a sound limiting thing, it just ups the volume a bit as speed increases…, so shouldn’t be your problem… that said, it obviously was…. Strange.
8th May 2022 4:58pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 189 |
Same, I’ve turned off the logic 7 for music and it’s much better- the logic 7 is best used for the tv’s as it adds surround sound really, not great with music 2007 TDV8 Vogue SE
10th May 2022 8:36am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1329 |
There's someone on the forum who has replaced their stock low/mid range speakers with retrofit PAS ones and he says the audio quality is way better. 2015 Range Rover Autobiography 4.4 SDV8 |
10th May 2022 2:23pm |
