Home > Off Topic - Other Cars > Best adhesive/ sealant - repair hole in rubber door seal?
pld118
Hi, I’ve a car with a slight hole in the rubber driver’s door seal (pictured). What’s the best black coloured adhesive or sealant to neatly repair/plug this please?
The seal is otherwise in excellent condition but I want to reduce the risk of water getting in the hole and causing underlying damage.
Thanks
Post #631074 9th May 2022 12:48pm
I doubt whatever you do the end result will either not work or fail shortly after. I’d be inclined to bit the bullet and buy a new seal. Thumbs Up
Post #631097 9th May 2022 6:25pm
Kot
Have you tried super glue? 2018 SE SDV8 4.4 Byron Blue
Post #631102 9th May 2022 6:46pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
How about a bicycle puncture repair kit, should do the job.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #631106 9th May 2022 7:17pm
pld118
Thanks for the replies. A new seal is £771.66 plus VAT.
There’s no wind noise and the seal is otherwise very good. I’ve tried Loctite Super Glue 3g Ultra Gel. Repair looks tidy and as though it has worked. Time will tell…
Puncture repair kit was on my list as well 👍🏻
Post #631111 9th May 2022 8:05pm
£771.66 plus vat. Good god, I’d live with the hole. Rolling with laughter
Post #631115 9th May 2022 8:22pm
pld118
That’s why I opted for a £1.50 tube of glue 😂
Post #631140 9th May 2022 10:20pm
Merchy
I used something like this on some very flexible shoe soles, black and quite flexible, not too expensive if the current repair doesn't hold
https://www.googleadservices.com/pagead/ac...amp;adurl=
Post #631142 9th May 2022 10:31pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
A bit of black gaffer tape. Sorted!!
Post #631144 9th May 2022 11:03pm
mpirie
I would second Merchy''s suggestion for Stormsure adhesive.
It's designed to seal leaking wellies etc, and does the job well Thumbs Up
Mike
Post #631162 10th May 2022 8:51am
pld118
Thanks for all the replies Thumbs Up
I used the above mentioned Loctite glue yesterday and it seems to be a tidy and strong (very minor) repair, although not water tested yet (albeit the glue dries clear and not black which isn’t good for my OCD Laughing
Also ordered a tube of the Stormsure adhesive today which should arrive tomorrow and which looks/ sounds just the job 👍
Ps… tried gaffer tape and couldn’t get it to stick. Maybe my roll of tape isn’t so good Thumbs Up
Pps… the reason I examined the seal was because I noticed a very small area of carpet smelling damp on the driver’s door sill which is surrounded by said seal - seal is one piece and goes all the way around the driver’s door frame and sill. When I found the pictured hole I wondered if water had gotten inside via that hole and had maybe pooled in the sill area near the carpet, hence slight musty/ damp smell. The car doesn’t get exposed to rain, it’s garaged and it’s only my washing hose likely to be causing any wet carpet… so the morale of the story is, stop washing it Laughing
Post #631207 10th May 2022 5:31pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
use black pu sealer like tiger seal pump some in the hole and let it come out leave it dry till next day and then cut of surplus and shape it new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #631225 10th May 2022 8:17pm
