Home > Technical (L322) > Radio Code
Googs
Australia
Radio Code
G’day, have had to fit new battery as the cold has killed this one (L322 03) model. but in doing it I have to re-enter the 4 digit pin which I have, as I enter I find there’s no box with enter in it only “ change “ or deactivate.
My question is to any one that can help me with the sequence you go through to enter the 4 digit pin.
Thanks in advance 🇦🇺
Post #632502 22nd May 2022 3:21am
Googs
Australia
What I mean is after you enter the 4 digits what do you do next?
Post #632757 24th May 2022 10:08am
mjdronfield
I don’t think it has a radio code.
There is an immobiliser code, that you can set yourself that has to be entered before the car will start….
More info here….
https://www.fullfatrr.com/forum/topic13354.html?highlight=code
https://www.fullfatrr.com/forum/topic9498.html?highlight=code 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #632762 24th May 2022 11:24am
Googs
Australia
This is what i have been doing, so I’m guessing that the radio amplifier is toast (in the boot)
I have work to do and this system is a PITA…..parts for BMW audio systems are getting harder to find!
From what I’ve read on the forum is that water gets in the rear corner onto the electronics and fries them, is there a way to stop this from happening apart from relocating the amplifiers?
Thank you mjronfield, i can now get on with the repairs. Very Happy
Post #632807 24th May 2022 8:36pm
mjdronfield
The amplifier won’t cause this issue I don’t think. A couple of members have had the car do this after disconnecting battery, and I think the emergency deactivation worked after a few tries. Ignition on, and a countdown from 10 or 15 minutes starts… you wait and then should be ok. From memory that…
Re the amp, Land Rover sell a “water shedder” to protect the electronics, but it’s just a plastic bag that goes behind the frame.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #632812 24th May 2022 9:15pm
mjdronfield
This is what I was looking for….
https://www.fullfatrr.com/forum/topic60259...deactivate
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #632815 24th May 2022 9:43pm
Googs
Australia
Thank you, i will give it a try just to get myself familiar with the system……a plastic bag aye, geez that inventive !!
Also I’ve noticed the the orange light doesn’t come on the audio screen….i do remember this coming on a good while ago.
Dose this mean the head unit isn’t working?
Post #632817 24th May 2022 10:27pm
mjdronfield
Everything is controlled from the boot. The screen is literally just a screen, with a tape deck behind it.
Water shedder info…. Part number at the bottom
Technical Service Bulletin No. LTB00007v2 31 May 2007
Subject/Concern: Navigation System Inoperable/Rear Quarter Water Ingress
Models: Range Rover (LM) - Vehicles With Sat Nav - Vehicles With Sat Nav VIN- range: Up to 6A226169
Markets: All
Section: 419-07
Section: 86
Summary: A customer may report a concern that the satellite navigation system does not operate and only displays the Land Rover logo. In some cases the radio and/or the telephone bluetooth functionality may also be inoperative.
This Version has been issued due to a change in the Service Procedure to carry out L8803BU, in order to ensure the route cause of the water ingress is also investigated.
Cause: Water ingress in the area of the left-hand rear quarter light glass or body panel may enter into the navigation unit resulting in the above complaint. However, in extreme conditions water ingress may effect any/all of the following modules (dependent upon model year and vehicle specification):
�Telephone control unit (TCU).
�DVD Player.
�Satellite digital audio radio system (SDARS) tuner/receiver - (NAS only).
�Power Amplifier.
Action: Should a custome express concern regarding the above, refer to the Service Procedure detailed in this bulletin to install water ingress protection when renewing the navigation unit.
Parts Required: Shedder - tall door
Part Number: EOT500030
Quantity: 1 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #632823 24th May 2022 10:41pm
Googs
Australia
So if the orange light isn’t glowing above the left side rotary knob does this mean the screen is toast or the radio amplifier?
I have worked out the the red flashing light (top right side ) is something to do with the Telephone.
Is there an easier system that l322 owners have fitted in their vehicles?
2002 l322 Range Rover Vogue sat/nav TV CD tape player
2006 Roush 427hp Supercharged Mustang
Post #632841 25th May 2022 9:14am
Googs
Australia
So the orange light above the LH rotary knob is that controlled by the radio unit in the boot OR the screen ?
Post #633023 27th May 2022 3:12am
