![]() | Home > Maintenance & Mods (L405) > TV Screen removal |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
Can I ask, Why do you want to remove the screens ? I would not think it would be a easy task as they tilt / move as the front seats do, so expect there is a complex mechanism in the seat back and also these are wired up to a slave and master controller ( under N.S.F seat) that would need to be disconnected. These units talk to a lot of other units in the car like the Center info display, radio etc. if disconnected May cause fault codes and other parts of system not to work. Not tried it but that’s what I think. |
Paddy Member Since: 29 Jun 2016 Location: London Posts: 14 ![]() ![]() ![]() |
Thanks. I have got used to them now. I wouldn't neceserily spec them but I think it's just the fact I am not used to seeing them that put me off. |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 257 ![]() ![]() ![]() |
Digging out an old post, I need to remove a screen on the driver seat, any suggestions?
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1525 ![]() ![]() ![]() |
It pretty easy, small tab on top of the bracket where it joins the seat, then a couple of torqs screws. I will see if i can find an old thread.
