![]() | Home > Maintenance & Mods (L322) > Lifespan of rear bags |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Gents as most know I do long journeys in my fattie so question is would it be prudent to swap the rear airbags more of my preventative maintenance as they are the originals and have done 225k miles and also are 15 years old in June ? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
Given the complexity of the system you should (following preventative maintenance logic) replace the compressor, airlines, valve blocks , air tank
Fronts and compressor were changed about 6 years ago and it is showing no faults but dont really want to get stuck a thousand miles from home so might change them and the dampers |
I rarely sell a car still have my classic and p38 in the back garden both with mot but dont get used much |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 159 ![]() ![]() |
May I ask why you don’t fix the air tanks? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
I changed the rears on mine in November, Sandy. They still looked in good shape when I removed them but I figured that seeing as I was in there doing the rear shocks I'd do the rear bags.
Like your workshop..... 2012 TDV8 Vogue (L322) |
Great finish on that David
Thanks guys |
Great write up David, thanks for sharing mate
Thanks!
Brilliant David might as well do it all in one go ![]() ![]() |
