Home > Technical (L322) > Air con intermittent - is this the PCV issue? 4.4TDV8
garyRR
So, my air con works however, only when travelling at faster speeds or accelerating.
The air con doesn't often work at low speeds or will switch off when stuck in traffic.
Is this the known PCV issue or something else? 2015 Range Rover Autobiography 4.4 SDV8
Post #634985 19th Jun 2022 7:15am
DrRob
Sounds like it. Does it takes ages to go cold too?
I had an Advanced Factors one fitted and all is good Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #634988 19th Jun 2022 8:39am
garyRR
From a cold start up, the car takes about 5-10 minutes for the air con to kick in. It remains working so long as I'm driving at speed.
As soon as I get stuck in traffic, it just blows warm air after a few minutes. 2015 Range Rover Autobiography 4.4 SDV8
Post #634993 19th Jun 2022 9:39am
I thought it was called the RCV....
Anyway loads of info here...
https://www.fullfatrr.com/forum/topic43778.html? Pete
-Click here for Thread-
Post #634994 19th Jun 2022 10:01am
Phoenix
It could also be a low refrigerant charge. It'd be worth getting it recovered to check the charge weight against spec.before jumping in and replacing the RCV.
Post #634995 19th Jun 2022 10:19am
