Home > Maintenance & Mods (L322) > Learning to change oil and filters
dhallworth
No, it's right at the top by the filler.
You can see Sam using it in his video. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #634175 9th Jun 2022 4:33pm
garyRR
If sucking the oil with a pump, the drain pipe is next to the oil filler on the top of the engine.
If draining the oil, no you don't need to remove the radiator splash shield. The sump is clearly visible underneath the car and the aforementioned hose to unclip is on the offside of it. It needs both clips pushing in whilst given a little wiggle towards the offside of the car. Be prepared. All 9 litres will dump in c. 2 minutes.
I flatten the box the oil gets delivered in and put on the driveway as the "splash zone". 2015 Range Rover Autobiography 4.4 SDV8
Post #634177 9th Jun 2022 4:38pm
Vipster
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Thank you. I see what you mean. The hose to which Sam connects the suction pump.
I thought there was another drain hose under the engine. Thanks for clarifying.
Post #634178 9th Jun 2022 4:39pm
garyRR
There is... the hose under the engine drains the sump when disconnected.
The 'pipe' on the top of the engine is for sucking. 2015 Range Rover Autobiography 4.4 SDV8
Post #634179 9th Jun 2022 4:41pm
Vipster
Wonder why the new design instead of the traditional sump plug. Is this more efficient?
Post #634180 9th Jun 2022 4:41pm
garyRR
For that, I have no idea. I'm sure some will claim due to "cost" however, sump plugs are c.£1-2 and Ford did a pretty good job at re-designing and replacing the BMW things which didn't work on these cars, at presumably great expense, so, doubt it really is due to cost.
So, you have two options for an oil change. One requires a pump but is 0 mess. One can be messy but requires no pump. 2015 Range Rover Autobiography 4.4 SDV8
Post #634181 9th Jun 2022 4:47pm
Vipster
Thanks Gary.
Such a great forum and forumites.
Post #634182 9th Jun 2022 4:58pm
garyRR
I just remembered I actually did a step by step how to guide with pictures.
Should give you everything you need to know:
https://www.fullfatrr.com/forum/topic60560.html 2015 Range Rover Autobiography 4.4 SDV8
Post #634187 9th Jun 2022 6:17pm
Vipster
Thanks Gary.
I managed to take the cabin filter off and put it back. That's my first time ever and quite pleased with myself.
Decided to remove the battery to charge but couldn't as ECU was in the way .
Will attempt air filter tomorrow.
I do feel more confident than this morning but the oil change will be the most difficult, I imagine.
Post #634202 9th Jun 2022 8:23pm
Baltic Blue
Do the drivers side first, because that is always the dirtiest.
I did mine earlier this week.
Don’t completely remove the screws from the lid to reduce the risk of dropping any, leave them in a couple of threads.
Post #634203 9th Jun 2022 8:35pm
Vipster
Well done and thank you.
I will do the driver's side first. Fingers crossed it will go well and I don't break any plastics.
Post #634204 9th Jun 2022 8:39pm
