![]() | Home > Technical (L322) > DPF full turbo problems? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Doesn't sound good. I'd take it to a specialist for their assessment if it were me. Henshalls Enginnering nr you Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3325 ![]() ![]() ![]() |
How many miles, is it using oil and what’s the service history? An intake air leak will cause the DPF to fill up as it will run rich. Oil in the DPF may be just from the 2nd turbo if it hasn’t had the drain mod. As Rob says get a specialist to look at it. Not unknown for turbo’s to fail but not common on these engines unless they have been abused or neglected. 2012 TDV8 Vogue (L322) |
Tomstrum Member Since: 12 Jul 2022 Location: liverpool Posts: 3 ![]() ![]() ![]() |
Hi, thanks both for taking the time to reply.
I haven't noticed it using any oil and theres been no smoke. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
do you have an IID gap tool diagnostic? you can use it to force a DPF regen, (in service menu) and that might clear it. you might also have the common exhaust sensor failure (p0040d) which means the DPF cycle wont trigger, because the sensor sees it 'not hot' and thus cycle wont happen. dont take this as gospel, but this was my issue, and with help of tool, i got mine regen'ed, and its working fine now.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
deleted by author 2012 L322 4.4 TDV8 AB low mileage - a peach
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
There's well documented DPF issues and the usual culprits on this this forum for the 4.4 TDV8. All these jobs you can do without spending any money and seem to permanently resolve the DPF filling issue for many: 1. Firstly, sounds like the MAP sensor you reference. It gets gunked up every few thousand miles on most cars and needs cleaning, otherwise it is susceptible to sending wrong readings to the ECU, leading to too much soot in the exhaust or running rich, causing the DPF to fill. Maybe add it to your maintenance schedule - it's a VERY common cause. Allow time for a couple of DPF regens (aka do a good 20 miles on a motorway for no reason if you have to) 2. Conscious you're getting this done but this is a very common cause: The union from the charge hose to the throttle body on the inlet manifold is prone to the double lip seal failing (due to poor design). Loads on this forum about it but if you look at the top of the engine, it's the plastic bit with a metal clip around it attaching it to the throttle body. It only takes a few minutes to remove and have a look. If there's intake gunk in that vicinity or on the throttle plates (you'll see them when it's removed), it's a good sign it's this pipe. It's very expensive for what it is (£170) but this often permanently fixes the issue of the gunk in the intake and DPF filling for many members on this forum. My seal is on the verge of failing and before replacement, I am trialling a wrap of gas spec PTFE (which costs 40p) to see if it will re-seal and will report back when I've done a few thousand miles. 3. Check every hose connecting the inlet manifold. Have a good feel for seepage. Also look at the top 2 charged air hoses on top of the engine bay - I once had a split in one on another vehicle which was nearly impossible to notice until I took the hose off and had a look with a torch 4. You can check the turbo hoses relatively easily on this engine. The left side turbo lower hose can be inspected easily by just pulling out the left airbox (removing the M8 nut on the glowplug assembly first). The other turbo is also pretty straightforward to check visually. Once you've had a good inspection yourself for the common issues, I'd then look at spending money on further diagnosis, such as a smoke tester or the exhaust gas sensor (not expensive but a pig to get to) which is what I would think about next. 2015 Range Rover Autobiography 4.4 SDV8 |
