Home > Technical (L322) > 2008 L322 HSE Not starting
Blankone
United Kingdom 2009 Range Rover Vogue 4.2 SC V8 Buckingham Blue
Hi, wondering if anyone can shed some light on a non start issue on a 2008 HSE 4.4, starter engages spins the engine over but wont start, the comfort start just keeps whizzing the engine over, IID tool came up with B1101-73 (2Cool comfort relay-mechanical failure-actuator is stuck closed.
Google has not thrown up much on this so this so the question is where is the relay/actuator located as I cant find it, starter works fine, battery volts fine so am scratching my head a little any help gratefully accepted.
Post #449137 26th Aug 2017 9:32am
Danwilderspin
Did you ever fix this I have a similar issue starts second time round every time with the same code Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633167 29th May 2022 3:52pm
DanPoole
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
Hi,
I’m having the same issue and code. Car starts 2/3rd attempt.
Did you manage to resolve this?
Thanks 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #638367 31st Jul 2022 5:18pm
Danwilderspin
Fuel system related failed non return valve on pump was letting the fuel from the line seep back in but cranking a couple of times filled the line up Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #638375 31st Jul 2022 7:15pm
DanPoole
Appreciate the reply, Dan!
Was it a costly repair, or fairly straight forward? 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #638377 31st Jul 2022 7:20pm
Danwilderspin
To be honest different engine I know but I was lucky enough to have been donated a spare fuel pump (used but working) so I did it myself time consuming but not costly Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #638384 31st Jul 2022 8:40pm
