Home > Maintenance & Mods (L322) > Clunk noise when turning Steering left or right?
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Any suggestions on cause of this here please? Although after replacement of upper and lower steering arms both sides a few years ago this clunk still remained. The MOT failure - one faulty ball joint. The garage took advantage to go beyond this though. No pointers from following MOT's since then but it is perhaps becoming a bit more frequent. I took the L322 to a different local garage last week which couldn't find any fault , nothing loose or wrong etc. suggesting a MD have a look at it.
No steering issues when driving just this odd clunk now and again over the last four years? I assume I am safe but good to know if something does need changing.
Any comments welcome.
Thanks
Dave
Post #638908 7th Aug 2022 11:42am
dingg1
Change the anti roll bar drop links, they are cheap and easy enough to do... Thumbs Up
Post #638915 7th Aug 2022 12:45pm
That could be anything....
from wheel bearings to struts, suspension arms, subframe bushes, steering rack....etc etc...
As said drop links are the cheapest if you just want to change things..
Get it to a good independent Land Rover specialist they should be able to help... Thumbs Up Pete
Post #638945 7th Aug 2022 5:35pm
Nylands
Clunk noise
I’ve changed the anti roll bar bushes and link bars as suggested and agree that I have to find a good Independent. Just surprised that the garages I have used can’t answer it? Perhaps they didn’t look for sub frame bushes etc but it does handle well. I do have an Independent not so far away but he is known to be a bit of a rip off merchant.
Thanks guys
Dave
Post #638975 7th Aug 2022 11:08pm
JayGee
The odd noise now and again over 4 years and the garage can’t find anything wrong - forget about it Smile 2012 TDV8 Vogue (L322)
Post #638989 8th Aug 2022 9:20am
You are not far from our own Cam Tech Craig, he's between Bristol and Gloucester... Thumbs Up Pete
Post #638990 8th Aug 2022 9:34am
Nylands
Clunk from the front
Thanks for the replies guys.
It’s making a fool of me now as I used it this morning and heard it three times? Having it looked at another garage tomorrow with me there as well, they might find something? I’ll update this post if anything resolved tomorrow.
Cheers Dave Big Cry
Post #639014 8th Aug 2022 12:17pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Have you tried a wheel alignment? I had a clunk / knock from the rear right. Had it realigned after replacing the rear diff seal and the noise was gone!
Post #639216 10th Aug 2022 6:23pm
Nylands
Clunk noise
Thanks vs322.
Just shows how difficult it is to identify those things. We confirmed at the garage Tuesday that the suspension at the front was ok. "Its the front right side" but not sure what after that. I'll have a check that things are tight when it cools down next week as the next stage. Pleased that my quote for two more lower end bars wasn't the fault and then still having the clunk after their replacement.
Post #639260 11th Aug 2022 8:24am
Tiprat
Good morning guys, we had exactly the same symptoms on the RR we "borrowed" for a year, it came with the knocking and I did most of the things mentioned above but still couldn't find it, then one day when the car went in for its MOT, the tester "found" the fault. It was a loose bolt on the steering rack, a quick tighten up and, noise gone!!
So it could be something as simple as a loose bolt. Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #639264 11th Aug 2022 9:10am
vs322
Yes, it can indeed be something as simple as a loose nut. I thought it was the rear subframe bushes in my case. Glad it wasn't.
Another time I had a horrible knock on the front of my freelander. Garages and MOT could not pinpoint the source. Turned out to be a loose nut on the lower engine mount. Took only a quarter of a turn. Been quiet as a mouse ever since.
Post #639265 11th Aug 2022 9:19am
Nylands
Clunk noise
Thanks guys points on my list to check, that would be a great solution!
Post #639284 11th Aug 2022 11:27am
Nylands
Hi anyone,
How do I request help from Craig ( Cam-Teck-Craig) on this. Had a couple attempts at sending him a private message but it seems i sent them to myself?? Big Cry Big Cry
Dave
Add on: he has been in touch now - thanks
Post #639714 15th Aug 2022 4:36pm
