| FBH Not working no faults IID tool | |
Good afternoon, 4.4SDV8 2015 VSE Yesterday 0 degrees the car took an age to warm up, so today i scanned it with the IId tool, i have no faults, start the car and no activity from the FBH , currently 2 deg C so should kick in under 6 if my disco is anything to go by.
On my D3 & D4 sdv6 using IID trool you could activate teh FBH in service / test section on IID tool , butr there is no listing on the RR?
Build sheet says
Suplimentary heating Fuel burning
Block heater Less
In the CCF file FBH down as being present, i changed the CCF to timed climate and this brought up the tab in the touch screen on the dash, activated manual heat and the system goes through the sequence but blows cold air, no FBH running, set a timed climate and it all goes through and blows cold air, with teh engine running the FBH does not kick in its stone cold after 5 minutes with only tepid waterr pipe temp from the engine, yesterday i left malham yorkshire and got to full engine temp after 7 miles as the roads were litterd with fallen trees debris and ice so i hardly got more than 1200 rpm, this cant be good for the motor and aint too cracky inside either, reminded me of a escort diesel van i had 25 years ago..
Any ideas peeps, as im lost without being able to run it via IID plus no error messages all seems strange to me, my D3 would lock out on low fuel, but you could clear it using iid and prime the FBH , but i can not see it in any menues... advice welcomed.
Pat
SDV8 2015
