Home > Technical (L322) > PO700 fault code
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
PO700 fault code
Anyone had this, from what I can gather it's transmission related but when plugged in to diagnostics there are no faults in transmission but this code comes up as an engine fault code , just happened (brought EML light on ) and I can't clear it down (permanent fault) but can't seem to find any info on it , no noticeable affects on how it drives , confused dot com .
2011 TDV8 4.4 btw .
Matthew
Post #642026 5th Sep 2022 10:42am
dingg1
https://www.mycarspecs.com/obd2/land-rover...il-request
Gearbox oil change as first step?
Post #642030 5th Sep 2022 10:50am
matthews
Thanks for that , had oil and filters changed about 25k miles ago , came on first time at startup when stationary , didn't come on whilst driving ?? and having looked through that info it all relates to whilst in use , and no fault codes showing up in transmission ECU
Post #642037 5th Sep 2022 11:25am
dingg1
Rrphil may pipe up with a better reply if he's seen the problem and reason before
Good luck and hopefully not too serious or costly to resolve Thumbs Up
Post #642049 5th Sep 2022 12:52pm
kevinp
Did you manage to resolve this problem? Mines just showed this code along with P2459 and P0195.
Thanks Kev.
Post #680834 20th Dec 2023 6:07pm
CarlM93
Hi guys, i have the exact same issue after a flat battery.
Drives perfect just the p0700 code
Any advise ?
Thanks
Post #721350 15th Jul 2025 8:33pm
CarlM93
UPDATE - I took the car on 3 drive cycles and eml light went off on its own
Post #721656 21st Jul 2025 10:57am
