Home > Technical (L322) > Weird unlocking issue 2011
GGDR
Hi team,
Button on fob recently started needed two unlock presses to let me open the boot and passenger door.
Drivers door unlocks with one press.
Any tips?
. Cheers, Greg
Post #642535 9th Sep 2022 7:01pm
mjdronfield
I thought that was how it was supposed to work.
Mine works like that.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #642537 9th Sep 2022 7:17pm
mjdronfield
Looks like you can change it by pressing lock and unlock buttons together for a few seconds.
Get it operating how you like it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #642538 9th Sep 2022 7:20pm
garyRR
Yes, you can change the settings with the remote or with the IID tool.
I believe it's called "easy unlock".
Does anyone else have their seat set to lower when they open the door (as well as the steering wheel retracting)? 2015 Range Rover Autobiography 4.4 SDV8
Post #642542 9th Sep 2022 7:47pm
GGDR
And here was me thinking there was a fault....
Further shame on me - the answer was in the manual.
Great thing is, this is the biggest (non) issue I've had on the Range Rover in ages
Thanks guys! Cheers, Greg
Post #642556 9th Sep 2022 11:21pm
mjdronfield
The thinking was that you wouldn’t want to unlock all your car if you were alone at night, in case someone got in another door…… or maybe that’s me just spreading nightmares 😱
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #642557 9th Sep 2022 11:31pm
garyRR
...depends where you are and what activity you're up to... 2015 Range Rover Autobiography 4.4 SDV8
Post #642558 9th Sep 2022 11:35pm
mjdronfield
Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #642575 10th Sep 2022 11:14am
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
Has anyone had a change in mirror light behavior regarding one press lock vs two press lock? On my MY07 mirror lights worked just fine when it had two press lock but now that I changed the setting with IID-tool to one press lock, mirror lights practically just blink and off they go. The cherry on the cake is that now, even if I change back to two press lock, mirror lights just blink and I can´t get them back to normal operation Sad
Post #642612 10th Sep 2022 6:06pm
KF
Anyone?
Post #643043 15th Sep 2022 3:54pm
Try putting them how you want, then do a battery reset, if you play with the CCF you sometimes have to do a reset.. Thumbs Up Pete
-Click here for Thread-
Post #643049 15th Sep 2022 5:35pm
KF
Battery has been disconnected once after the change in configuration, will try again.
Post #643092 16th Sep 2022 7:30am
KF
Changed the FBH few days ago and had the battery disconnected for over an hour, still no change in mirror light behaviour, just a blink when opening the door locks.
Post #646625 27th Oct 2022 11:47am
DrRob
Easy Unlock is on the instrument panel menu iirc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #646657 27th Oct 2022 9:00pm
