Home > Technical (L322) > Diesel Additives.
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Diesel Additives.
I have read a few posts on here relating to improving engine efficiency via premium diesel, fuel additives and 2 stroke oil. I was a little confused by the end of it!
My car has close to 143,000 on the click and has regularly been serviced from new by the same main dealer, it generally sounds fine on tick over to my untrained diesel ear.
However I would like to try something as a test to see if it can run a bit cleaner / and or more efficiently. For all I know it’s as good as it can get but would like to give something a go to improve it.
So my question is - is there anything I should avoid? I understand the opinions on additives in whatever form generally go from positive to ‘snake oil’, but there have been some positive reviews for the likes of BG44 etc.
Interested to hear any and all opinions on any of the above.
Thanks
Kit
Post #644005 26th Sep 2022 1:39pm
JayGee
Tried a few on various cars inc (BG44 and 2 stroke) - never did anything apart from lighten my wallet . If I had a 3.6 the first thing I'd be doing is to blank and software delete the EGR valves before they go wrong. Plenty of reports of these engines running better after this and turbo's being spared death by egr parts ingestion. 2012 TDV8 Vogue (L322)
Post #644016 26th Sep 2022 2:58pm
KitTheRam
Interesting. Are there any know problems from deleting the EGR’s (guessing not by your note).
What should I expect a specialist to charge for it? ECU software needs changing too I presume?
Post #644018 26th Sep 2022 3:03pm
JayGee
When I was looking to buy an L322 a 3.6 was an option so I did some research on it ( Blanking plates from Ebay and software delete via the GAP IID tool) but best get advice from others who have actually done it as to what improvement it made and what the downsides are. 2012 TDV8 Vogue (L322)
Post #644019 26th Sep 2022 3:10pm
kevinp
I had a very noisy injection pump and put some Millers ecomax in the tank and the noise went away. Coincidence?
Post #644022 26th Sep 2022 3:45pm
supershuttle
I regularly used BG44 in my 3.6, it did no harm but then again did it do any good? Geoff
Post #644023 26th Sep 2022 3:46pm
pcourtney
speak to Empire in Colchester - one of the very best remap shops around for Range Rover ( and not far from you)
they can sort out the software re EGR and DPF, also give you good advice, and whilst there you could do a nice remap for your 3.6 lump - better fuel economy, more torque Smile
https://www.empiretuning.co.uk/contact/
Post #644025 26th Sep 2022 4:04pm
KitTheRam
What little I have read on EGR deletes included mentions of it being an mot failure if spotted. Not sure how true that is but read it a few times now. Also issues with the engine management light seem common. But I guess if done by a specialist garage these issues would have solutions, you would hope.
Post #644026 26th Sep 2022 4:07pm
KitTheRam
Thanks for the tip @pcourtney.
Post #644027 26th Sep 2022 4:09pm
pcourtney
speak to Empire first, they are able to do all this in softeware without falling foul of the MOT regime etc
Post #644032 26th Sep 2022 5:46pm
Phoenix
Blanked / missing EGR's are a MoT fail.
Be careful with additives, most manufacturers prohibit their use unless instructed by tech. support (Yes, I know a lot of dealers, JLR included, try and upsell them on services - 'oil flush' is also prohibited and potentially just as bad for your engine.) Additives can alter the burn temperature and contaminate DPF /CAT with substances that are irremovable.
Due to reduced Sulphur fuel not having the lubricating qualities the fuel system was originally designed for, I use Dipetane https://dipetane.com/ (Available from Amazon, the 5l bottles are more cost effective Wink ) I can't honestly say if it's improved the mpg or emissions as my 3.6 had fuelling and emissions issues when I bought it... I've been double-dosing (1l to a full tank) as a restorative measure, after 600 miles, the car idles better, accelerates more smoothly and doesn't smoke as much on 'enthusiastic' acceleration. It's also just gone through an MoT with emissions of 0.19m1 which isn't too shabby for it's age and mileage (155k).
Post #644033 26th Sep 2022 5:50pm
TDV8 Paul
Yeah- it is a MOT fail, but a tester would never see it as it’s a) under the bonnet and b) under the engine cover and they cannot and have no reason to lift it, so it would never get spotted 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #644036 26th Sep 2022 6:04pm
Phoenix
Yep, forgot to add the 'if modifications are visible' bit!
Some of those with 2.7TDV6's are feeling the pain of this as the missing pipes and blanks on top of the EGR's are visible (or not!) without removing any covers.
Post #644039 26th Sep 2022 6:15pm
KitTheRam
Thanks for the all advice so far.
As my car has had a full dealer service history is it likely the EGR’s will have been done as a matter of routine maintenance at anytime? Or is it just when they go pop they are changed?
I have a 2 page pdf list of every time Stratstone Nottingham had the car but the lists are quite top line as to what was done. E.g. Service plus tyre plus mot etc.
I’m a bit green on it all as this is my first diesel car I have ever owned.
Post #644043 26th Sep 2022 6:28pm
TDV8 Paul
The egrs will only ever be touched when they go bang 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #644044 26th Sep 2022 6:34pm
