![]() | Home > Technical (L322) > tow bar wiring |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I think I know what you are getting at, the wire coming from the plug in the spare wheel does not match the colour code for the towing plug 13-pin socket, the JLR socket is sealed against water ingress which makes it difficult to track where they go, I did pull it apart about 3 years ago but made no notes. |
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 ![]() ![]() ![]() |
I can confirm the 2010 onwards plug in the wheel well is plug and play with the tow bar wiring, although I believe this only to be for a 7pin connection. Not a problem for me as I only tow a trailer, rather than a caravan for example. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Here you go.......
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
(In reference to 2010-2012 cars) The car can be programmed for a 13 pin loom or 7 pin. By default, it is set up as 7 pin. It can be changed to 13 pin in the CCF files. I have 13 pin electrics fitted and 13 pin programmed to the CCF. I guess balloonengineer has an old loom they're trying to retrofit to the newer model? 2015 Range Rover Autobiography 4.4 SDV8 |
Mine had the two 7 pin sockets, I changed it to 13 pin and wrote the table above. BMW i3 Electric Car
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
Thanks for the replies, and especially the table, very useful
